عدد المساهمات : 18992 التقييم : 35482 تاريخ التسجيل : 01/07/2009 الدولة : مصر العمل : مدير منتدى هندسة الإنتاج والتصميم الميكانيكى
| موضوع: كتاب Mechanics and Strength of Materials 1 الخميس 26 أبريل 2012, 11:50 pm | |
أخوانى فى الله أحضرت لكم كتاب Mechanics and Strength of Materials 1 BOGDAN SKALMIERSKI Silesian Polytechnical University Gliwice, Poland
Subject Index Absolute derivative of a tensor, 289 Acceleration, 16 in general motion, 38 Addition of vectors, 2 d'Alembert's principle, 257 Amplitude characteristic, 330, 398 Angular momentum, 92, 227 Angular velocity vector, 32 Articulated joint, 106 Assur's point, 62 Asymptotically stable system, 296 Axode, 37 Average value, 376 Base resonance, 350 Bearing friction, 140 Betti's reciprocal theorem, 185, 186 Bilateral constraints, 253 Bilinear product, 6 Binet's equation, 78 Boltzmann's bodies, 182 Castigliano's theorem, 187 Central axis of a system, 98 Central axis of inertia, 164 Centre of impact, 234 Centrifugal moment, 159 Chebyshev's inequality, 397 Christofiel's symbol of the first order, 288 ChristoiTel's symbol of the second order, 289 Clapeyron's system, 185, 190 Coaxial vectors, 2 Coefficient of friction, 137 Coefficient of restriction, 91 Collinear vectors, 4 Conditions of inseparability, 151 Cone of friction, 138 Configuration of a body, 11 Configurational space, 291 Conservative system, 71, 75, 285 Constant of spring, 215 Constrained mechanical system, 250 Construction scale, 101 Continuous vector function, 9 Contravariant tensor, 286 Convergence of a vector-function, 9 Correlaton, 379 Correlation function, 382 Correlator, 385 Couple, 96 Covariant derivative, 290 Covariant tensor, 286 Crank-slide system, 55 Crank-yoke system, 59 Creep, 182 Cremona's method, 118 Cremona's polygon, 118 Culmann's line, 121 Culmann's method, 120 Cumulative distribution function, 373 Cyclic coordinates, 269 Degrees of freedom, 249 Derivative of a vector function, 10 Derivative of the Dirac delta function, 123 430 SUBJECT INDEX Differentiable vector function, 10 Differentiable constraints, 253 Dirac delta function, 122 Dispersion, 377 Dynamically balanced body, 232 Effort hypotheses, 217 Elastic limit, 145 Elastic buckling, 199 Energy, 70 Equations of circular motions, 231 Equations of disturbances, 295 Equations of equilibrium, 95 Ergodic process, 384 Error integral, 377 Euler's angles, 33 Euler's equation, 231 Expected value, 376 Externally determinate static system, 114 Fokker-Planck-Kolmogorov equation, 418 Fourier transform, 329 Framework, 195 Free-ends beam, 114 Free vector, 2 Frequency, 371 Frequency characteristic, 329 Friction, 136 of a cylinder rolling, 142 of rope against wheel, 141 on an inclined plane, 138 Friction angle, 138 Funicular polygon, 103 Hamilton function, 283 Hamilton's canonical equations, 284 Hamilton's principle, 258 Harmonic oscillator, 310 Heaviside distribution, 121 Helical motion, 40 Hodograph, 15 Holonomic system, 252 Homeomorphism, 11 Homogeneous body, 81 Hooke's law, 147 Horse power, 72 Huber-Mises-Hencky hypothesis, 217 Hyperharmonic resonance, 350 Ideal constraints, 256 Inertia ellipsoid, 226 Influence function, 324 Influence matrix, 185 Instantaneous centre of acceleration, 52 Instantaneous centre of velocities, 49 Instantaneous helical axis, 39 Instantaneous power of a force, 71 Instantaneous rotational axis, 36 Internal magnitudes, 129 Intervally linear system, 337 Isotropic space, 11 Joule, 70 k-fold statically indeterminate system, 151 Kinetic energy, 70, 71 Kronecker's symbol, 6 Krylov's method, 341 Gauss normal distribution, 377 Gaussian process, 382 Generalized coordinates, 20 Geometric constraints, 252 Geometrical statical moment, 81, 82 Lagrange equations of impulsive motion, 275 of the first order, 262 of the second order, 268 Lagrange kinetic function, 269 SUBJECT INDEX 431 Lagrange kinetic potential function, 260 Lagrange multipliers, 262 Lagrange-Dirichlet criterion, 297 Laplace's transform, 318 Lapunov function, 299 Lapunov's theorem, 299 Law, 255 if action and reaction, 70, 274 of conservation of mechanical energy, 71, 75 of conservation of angular momentum, 93 of variation of angular momentum, 92 of variation of momentum, 87 Linear dependence of vectors, 6 Logarithmic decrement, 321 Matrix of transmittance, 367 Matrix of velocity gradient, 27 Menabrea's theorem, 190 Mean quadratic deviation, 377, 379 Modulus, 2 of rigidity, 149 of section, 166 of a vector, 9 Mohr's analogy, 173 Mohr-Maxwell canonical system of equa- tions, 192 Mohr-Maxwell equations, 212 Moment of deviation, 159 Moment of momentum, 92 Moment of a vector, 8 Momentum of a system, 86 Motion, 11 Newton, 69 Newton's second law, 69 Newton's third law, 69 Non-dilatation strain, 148 Non-holonomic system, 253 Non-oscillatory system, 308 Norm of a vector, 295 Normal stochastic process, 382 Node separation method, 118 Oblique bending, 159 Operator transfer function, 324 Orientation of a space, 8 Orthogonal coordinate system, 24 Orthogonal vectors, 4 Oscillatory system, 308 Parallel vectors, 2 Permutation symbol, 7 Phase characteristic, 330, 398 Phase plane, 308 Phase space, 352 Phase trajectory, 308, 352 Phase trajectory problem, 322 Plane truss, 117 Plastic limit, 145 Poisson number, 148 Polygon of forces, 101 Position of a body, 11 Position vector, 2 of the centre of mass, 80 Postelastic buckling, 199, 201 Potential, 70 Potential energy, 75 Principal axes of inertia, 164 Principal central axes of inertia, 226 Principal moment, 98 Principle, 255 Probability density, 375 Quantificator, 9 Quasi-harmonic system, 340 Radial velocity, 22 Random variable, 372 Radius of gyration, 225 Rayleigh's dissipation function, 277 Reduced moment, 218 Relative frequency, 371 432 SUBJECT INDEX Relative motion, 45 Relaxation, 182 Resultant vector, 98 Rheonomic constraints, 252 Right-hand screw rule, 32 Safety factor, 149 Scalar product, 5 Scleronomic constraints, 252 Self-locking inclined plane, 139 Sensitivity of a thermal bi-metal, 181 Simple bending, 159 Slenderness ratio of a rod, 201 Smoluchowski's equation, 420 Solidification hypothesis, 145 Spectral density, 392, 396 Stable solution, 296 Stable system, 293, 296 Standard equations, 340 Standard deviation, 377 Statical moment, 80 Statical-dynamical analogy, 369 Statically balanced body, 232 Statically indeterminate system, 151 Stationary motion, 303 Stationary process, 383 Steiner's equation, 162, 223 Stochastic process, 381 of the first order, 382 of the second order, 383 Strain of a rod, 147 Stress, 146 Subharmonic resonance, 350 Subtraction of vectors, 3 Tapering spring, 213 Tensile rigidity, 146 Tensor multiplication, 286 Tensor of velocity gradient, 27 Tetmajer's line, 202 Theorem on statical moments, 80 Time function of transmittance, 324 Torsional rigidity, 210 Transmittance, 324 Transportation, 45 Transverse component, 22 Triple-jointed system, 106 Truss, 117 Uniform space, 11 Unilateral constraints, 253 Unit vector, 4 Uncorrelated variables, 379 Variance 377, 379 Vector, 1 Vector function, 8 Vector product, 6 Velocity, 14 of a moving space, 41 of transportation, 41 Velocity tensor of a strain, 29 Velocity vector, 14 Vibration frequency of a harmonic oscilla- tor, 319 Virtual displacement, 254 Voight's model, 184 Watt, 72 White noise, 393 Work, 70 Wrench, 98
كلمة سر فك الضغط : books-world.net The Unzip Password : books-world.net أتمنى أن تستفيدوا من محتوى الموضوع وأن ينال إعجابكم رابط من موقع عالم الكتب لتنزيل كتاب Mechanics and Strength of Materials 1 رابط مباشر لتنزيل كتاب Mechanics and Strength of Materials 1
عدل سابقا من قبل Admin في الأحد 16 ديسمبر 2018, 10:38 pm عدل 4 مرات |
