كتاب Advances in Mechanical Engineering
عدد المساهمات : 18996
التقييم : 35494
كتاب Advances in Mechanical Engineering  Empty
مُساهمةموضوع: كتاب Advances in Mechanical Engineering    كتاب Advances in Mechanical Engineering  Emptyالسبت 10 أكتوبر 2020, 12:47 am
Selected Contributions from the Conference “Modern Engineering: Science and Education”,
Saint Petersburg, Russia, May 2018
Lecture Notes in Mechanical Engineering
Alexander N. Evgrafov Editor
كتاب Advances in Mechanical Engineering  A_i_m_17
Packing Compaction Algorithm for Problems of Resource Placement
Optimization . 1
Vladislav A. Chekanin and Alexander V. Chekanin
Wave Processes in the Periodically Loaded Infinite Shell 11
George V. Filippenko
Inspection of Welded Joints of New Pressure Vessels
Using the Acoustic Emission Method Capabilities . 21
Victor P. Gomera, Anatoly D. Smirnov, Evgeny J. Nefedyev
and Anastasiya V. Grigorieva
Reduction of Contact and Bending Stresses in the Bevel Gear Teeth
While Maintaining the Same Overall Dimensions . 35
Vladimir I. Medvedev, Dmitry S. Matveenkov and Andrey E. Volkov
Idle Milling System Noise Level Dependency from Temperature
Conditions of the Machine Working Area . 53
Artem V. Rasshchupkin, Kirill P. Pompeev and Viktor M. Medunetskiy
Tribotechnical Properties of Nanostructured Coppernickel
Coatings . 61
Margarita A. Skotnikova, Vladimir P. Artemyev, Svetlana A. Shasherina,
Olga V. Paitova and Galina V. Tsvetkova
Kinematic Synthesis of Programmed Motions of Drivers
of a Manipulator-Tripod with a Three-Degree Gripper . 73
Natalia S. Vorob’eva, Victor V. Zhoga, Ivan A. Nesmiyanov
and Andrey V. Dyashkin
About Implementation Harmonic Impact of the Resonance
Method 83
P. A. Andrienko, Vladimir I. Karazin, Denis P. Kozlikin
and Igor O. Khlebosolov
viiDetermination of Conjugated Profiles of Teeth in Cylindrical Gears,
Knowing Meshing Line in Face Section . 91
Dmitry T. Babichev, Sergey Yu. Lebedev and Denis A. Babichev
Modeling and Simulation of Dynamic Contact Atomic Force
Microscope . 109
Mohammad Reza Bahrami and A. W. Buddimal Abeygunawardana
Analysis of the Self-braking Effect of Linkage Mechanisms 119
Alexander N. Evgrafov, Vladimir I. Karazin and Gennady N. Petrov
To the Question of the Synthesis of Modifications Bennett’s
Mechanism . 129
Fanil F. Khabibullin, Ildar H. Saitov and Ilyas Z. Bagautdinov
Test Centrifuge Arrangement Analysis . 139
Arkady N. Popov, Mikhail N. Polishchuck and Nikolay Ye. Pulenets
Perspective Planetary-Layshaft Transmissions with Three Power
Flows . 153
Konstantin Salamandra
Study of Mechanisms with Allowance for Friction Forces
in Kinematic Pairs . 169
Yuri A. Semenov and Nadezhda S. Semenova
Size of a Zone Dangerous by Damage at the Root of Cruciform
Weld Joint . 181
Anton Y. Shlepetinskiy and Konstantin P. Manzhula
Vibractivity of Cycle Machinery Drives in the Accounting
of the Space Distribution of Working Bodies Characteristics . 191
Iosif I. Vulfson
Kinematics of the Connecting Rod of a Two-Mobility Five-Link
Space Mechanism with a Double Crank . 201
Munir G. Yarullin, Ilnur R. Isyanov and Alexander P. Mudrov
Calculation of Equivalent Stiffness of Corrugated
Thin-Walled Tube . 211
Tatiana V. Zinovieva
Vibrations of a Chain in the Braking Regime of the Motion
Mechanism in Load-Lifting Machines 221
Vassil D. Zlatanov and Svetoslav G. Nikolov
Author Index 233
رابط من موقع عالم الكتب لتنزيل كتاب Advances in Mechanical Engineering
رابط مباشر لتنزيل كتاب Advances in Mechanical Engineering
» كتاب Mechanical Engineering
» كتاب All About Mechanical Engineering
» كتاب Mechanical Engineering Principles
» كتاب A Brief History of Mechanical Engineering
» كتاب Mechanical Engineering Design
