عدد المساهمات : 18996 التقييم : 35494 تاريخ التسجيل : 01/07/2009 الدولة : مصر العمل : مدير منتدى هندسة الإنتاج والتصميم الميكانيكى
| موضوع: كتاب Robotic Welding, Intelligence and Automation السبت 13 يناير 2018, 11:34 pm | |
أخوانى فى الله أحضرت لكم كتاب Robotic Welding, Intelligence and Automation Tzyh-Jong Tarn, Shan-Ben Chen, and Gu Fang (Eds.)
Contents Part I: Intelligent Techniques for Robotic Welding Research Evolution on Intelligentized Technologies for Robotic Welding at SJTU . 3 S.B. Chen Image Processing for Automated Robotic Welding . 15 Peter Seyffarth, Rainer Gaede Automatic Seam Detection and Path Planning in Robotic Welding . 23 Kevin Micallef, Gu Fang, Mitchell Dinham Error Compensation and Calibration of Inter-section Line Welding Robot Based on a Wavelet Neural Network . 33 Su Wang, Xingang Miao, Yuan Yang, Xingai Peng Autonomous Seam Acquisition and Tracking for Robotic Welding Based on Passive Vision 41 Shanchun Wei, Meng Kong, Tao Lin, Shanben Chen A Framework of Intelligent Remanufacturing System Based on Robotic Arc Welding . 49 Ziqiang Yin, Guangjun Zhang, Hongming Gao, Huihui Zhao, Lin Wu A Fast GPI Line Detection Method for Robot Seam Tracking . 57 Bowen Li, Shengqi Tan, Wenzeng Zhang Mechanism Design and Kinematics Modeling of Irregular Cross-Section Pipeline Welding Robot . 65 Xinghua Tao, Hongwu Zhu, Lili XuVIII Contents Combined Planning between Welding Pose and Welding Parameters for an Arc Welding Robot . 73 Huanming Chen, Yichen Meng, Xiaofeng Wang Optimal Digital Filtering for Tremor Suppression in a Master-Slave Robot Remote Welding System 81 Hongtang Chen, Haichao Li, Hongming Gao, Lin Wu, Guangjun Zhang Coordinated Motion of Different Weld Robots Based on User Coordinates 87 Huajun Zhang, Chunbo Cai, Guangjun Zhang, Daming Shen Research on Information Transmission of a Welding Robot Based on Network . 97 H.B. Wang, G.H. Ma, D.H. Liu, B.Z. Du Survey on Modeling and Controlling of Welding Robot Systems Based on Multi-agent . 107 Chengdong Yang, Shanben Chen Research on the Robotic Arc Welding of a Five-Port Connector . 115 Jiyong Zhong, Huabin Chen, Shanben Chen Mixed Logical Dynamical Model for Robotic Welding System 123 Hongbo Ma, Shanben Chen Part II: Sensing of Arc Welding Processing A Method of Seam Tracking Based on Passive Vision 131 Long Xue, Lili Xu, Yong Zou Research on a Trilines Laser Vision Sensor for Seam Tracking in Welding . 139 Zengwen Xiao An Optimal Design of Multifunctional Vision Sensor System for Welding Robot . 145 Yanling Xu, Xiangfeng Kong, Shanben Chen Wire Extension Control Based on Vision Sensing in Pulsed MIG Welding of Aluminum Alloy. . 153 Lihui Lu, Ding Fan, Jiankang Huang, Jiawei Fan, Yu ShiContents IX Research on Track Fitting of Big Frame Intersection Line Seams . 161 Xingang Miao, Su Wang, Xiaohui Li, Benting Wan A Hybrid Approach for Robust Corner Matching 169 Fanhuai Shi, Xixia Huang, Ye Duan Depth Extraction by Simplified Binocular Vision 179 Gouhong Ma, J. Qin, F.R. Jiang, H.B. Wang Comparison of Calibration Methods for Image Center . 185 Xizhang Chen, Shanben Chen, Houlu Xue Seam Tracking and Dynamic Process Control for High Precision Arc Welding . 193 Huabin Chen, Tao Lin, Shanben Chen Feature Selection of Arc Acoustic Signals Used for Penetration Monitoring 203 Zhen Ye, Jifeng Wang, Shanben Chen Rough Set-Based Model for Penetration Control of GTAW 211 Wenyi Wang, Shanben Chen, Wenhang Li A Study of Arc Length in Pulsed GTAW of Aluminum Alloy by Means of Arc Plasma Spectrum Analysis . 219 Huanwei Yu, Shanben Chen Arc Sound Recogniting Penetration State Using LPCC Features . 229 Jifeng Wang, Yantian Zuo, Yichang Huang, Bo Yang, Song Pan Investigation on Acoustic Signals for On-Line Monitoring of Welding . 235 Na Lv, Shanben Chen A Study on Applications of Multi-sensor Information Fusion in Pulsed-GTAW . 245 Bo Chen, Shanben Chen Research on Image Process and Tracing of a Welding Robot . 253 G.H. Ma, L. Wang, G.Q. Liu, M. XiaoX Contents Part III: Modeling and Intelligent Control of Welding Processing Predictive Control of Weld Penetration in Pulsed Gas Metal Arc Welding 263 Zhijiang Wang, YuMing Zhang, Lin Wu Study on the MLD Modeling Method of Pulsed GTAW Process for Varied Welding Speed . 271 Hongbo Ma, Shanben Chen Simulation of Decoupling Control of Pulsed MIG Welding for Aluminum Alloy . 279 Ding Fan, Jiankang Huang, Lihui Lu, Yu Shi Modeling and Decoupling Control Analysis for Consumable DE-GMAW 285 Jiankang Huang, Yu Shi, Lihui Lu, Ming Zhu, Yuming Zhang, Ding Fan The Structure Design and Kinematics Simulation for Rotating Arc Sensor of TIG Welding Based on Pro/E 3D Design . 293 Jianping Jia, Hongli Li, Wei Jin, Shunping Yao Knowledge Model Building about a Motor Speed Regulation Fuzzy Control System 299 Huimin Zhao, Mingyan Ding, Wu Deng, Xiumei Li, Wen Li Research on Surface Recover of Aluminum Alloy PGTAW Pool Based on SFS 307 Laiping Li, Xueqin Yang, Fengyan Zhang, Tao Lin Research on Fuzzy-Prediction-Control of GTAW Process Based on MLD Modeling 315 Mingyan Ding, Hongbo Ma, Shanben Chen Application of Fuzzy Edge Detection in Weld Seam Tracking System . 323 Zhenyu Xiong, Wen Wan, Jiluan Pan Part IV: Welding Technics and Automations Application and Research of Arc Welding Automation in Korea . 333 Suck-Joo NaContents XI Offline Programming for a Complex Welding System Using DELMIA Automation . 341 Joseph Polden, Zengxi Pan, Nathan Larkin, Stephen Van Duin, John Norrish Robot Path Planning in Multi-pass Weaving Welding for Thick Plates . 351 Huajun Zhang, Hanzhong Lu, Chunbo Cai, Shanben Chen Influence of the Bar Shape on the Welding Quality of Friction Hydro Pillar Processing . 361 Xiangdong Jiao, Hui Gao, Hongwei Zhan, Canfeng Zhou, Jiaqing Chen, Yanqing Zhang Interference Analysis of Infrared Temperature Measurement in Hybrid Welding 369 Jifeng Wang, Houde Yu, Yaozhou Qian, Rongzun Yang Preliminary Investigation on Embedding FBG Fibre within AA6061 Matrices by Ultrasonic Welding . 375 Zhengqiang Zhu, Yifu Zhang, Chun Zeng, Zhilin Xiong Thermal Process Analysis in Welding Prototyping of Metal Structures . 383 Jian-ning Xu, Hua Zhang, Ronghua Hu, Yulong Li Study on Sub-sea Pipelines Hyperbaric Welding Repair under High Air Pressures 391 Canfeng Zhou, Xiangdong Jiao, Long Xue, Jiaqing Chen, Xiaoming Fang Part V: Special Robot Technology and Systems The Mechanism Design of a Wheeled Climbing Welding Robot with Passing Obstacles Capability 401 Minghui Wu, Xiaofei Gao, Z. Fu, Yanzheng Zhao, Shanben Chen Anytime Ant System for Manipulator Path Planning 411 D. Wang, N.M. Kwok, G. Fang, Q.P. Ha Path Planning and Computer Simulation of a Mobile Welding Robot 421 Tao Zhang, Shanben Chen The Control System Design of a Climbing Welding Robot Based on CAN Bus 429 Xiaofei Gao, Minghui Wu, Z. Fu, Yanzheng Zhao, Shanben ChenXII Contents An Implementation of Seamless Human-Robot Interaction for Pipeline Welding Telerobotics 435 Na Dong, Haichao Li, Hongming Gao, Lin Wu Design and Experiment of a Novel Portable All-Position Welding Robot 443 Bin Du, Jing Zhao, Yu Liu The Power and Propulsion of Medical Microrobots 451 Xueqin Lv, Rongfu Qiu, Gang Liu, Yixiong Wu Mechanical Design and Analysis of an Articulated-Tracked Robot for Pipe Inspection . 461 Z.Y. Chen, G.Z. Yan, Z.W. Wang, K.D. Wang Part VI: Intelligent Control and Its Applications in Engineering A Construction Method of Rational Approximation Model for Fractional Calculus Operators in Frequency Domain . 471 Wen Li, Guanghai Zheng, Bing Nie, Huimin Zhao, Ming Huang Research of Direct Discretization Method of Fractional Order Differentiator/Integrator Based on Rational Function Approximation . 479 Bing Nie, Wen Li, Haibo Ma, Deguang Wang, Xu Liang Blind Source Separation of Vibration Signal of Electric Motor Velocity Modulation System 487 Xiumei Li, Wen Li, Yannan Sun, Guanghai Zheng A Survey on Artificial Intelligence Algorithm for Distribution Network Reconfiguration . 497 Rongfu Qiu, Xueqin Lv, Shuguo Chen Author Index
كلمة سر فك الضغط : books-world.net The Unzip Password : books-world.net أتمنى أن تستفيدوا منه وأن ينال إعجابكم رابط من موقع عالم الكتب لتنزيل كتاب Robotic Welding, Intelligence and Automation رابط مباشر لتنزيل كتاب Robotic Welding, Intelligence and Automation
