عدد المساهمات : 18992 التقييم : 35482 تاريخ التسجيل : 01/07/2009 الدولة : مصر العمل : مدير منتدى هندسة الإنتاج والتصميم الميكانيكى
| موضوع: كتاب Essentials of Materials Science and Engineering الأربعاء 27 يونيو 2012, 3:31 pm | |
أخوانى فى الله أحضرت لكم كتاب
Essentials of Materials Science and Engineering Second Edition
Contents Preface xv About the Authors xix Chapter 1 Introduction to Materials Science and Engineering 1 Introduction 1 1-1 What is Materials Science and Engineering? 2 1-2 Classification of Materials 5 1-3 Functional Classification of Materials 9 1-4 Classification of Materials Based on Structure 11 1-5 Environmental and Other Effects 12 1-6 Materials Design and Selection 14 SUMMARY 17 9 GLOSSARY 18 9 PROBLEMS 19 Chapter 2 Atomic Structure 21 Introduction 21 2-1 The Structure of Materials: Technological Relevance 22 2-2 The Structure of the Atom 23 2-3 The Electronic Structure of the Atom 28 2-4 The Periodic Table 30 2-5 Atomic Bonding 32 2-6 Binding Energy and Interatomic Spacing 40 SUMMARY 44 9 GLOSSARY 45 9 PROBLEMS 48 Chapter 3 Atomic and Ionic Arrangements 51 Introduction 51 3-1 Short-Range Order versus Long-Range Order 52 3-2 Amorphous Materials: Principles and Technological Applications 54 3-3 Lattice, Unit Cells, Basis, and Crystal Structures 55 vii 3-4 Allotropic or Polymorphic Transformations 63 3-5 Points, Directions, and Planes in the Unit Cell 64 3-6 Interstitial Sites 74 3-7 Crystal Structures of Ionic Materials 76 3-8 Covalent Structures 79 3-9 Diffraction Techniques for Crystal Structure Analysis 80 SUMMARY 82 9 GLOSSARY 83 9 PROBLEMS 86 Chapter 4 Imperfections in the Atomic and Ionic Arrangements 90 Introduction 90 4-1 Point Defects 91 4-2 Other Point Defects 97 4-3 Dislocations 98 4-4 Significance of Dislocations 105 4-5 Schmid’s Law 105 4-6 Influence of Crystal Structure 108 4-7 Surface Defects 109 4-8 Importance of Defects 114 SUMMARY 116 9 GLOSSARY 117 9 PROBLEMS 119 Chapter 5 Atom and Ion Movements in Materials 122 Introduction 122 5-1 Applications of Diffusion 123 5-2 Stability of Atoms and Ions 125 5-3 Mechanisms for Diffusion 127 5-4 Activation Energy for Diffusion 129 5-5 Rate of Diffusion (Fick’s First Law) 130 5-6 Factors Affecting Diffusion 133 5-7 Permeability of Polymers 141 5-8 Composition Profile (Fick’s Second Law) 142 5-9 Diffusion and Materials Processing 146 SUMMARY 147 9 GLOSSARY 148 9 PROBLEMS 149 Chapter 6 Mechanical Properties: Fundamentals and Tensile, Hardness, and Impact Testing 153 Introduction 153 6-1 Technological Significance 154 viii CONTENTS 6-2 Terminology for Mechanical Properties 155 6-3 The Tensile Test: Use of the Stress-Strain Diagram 159 6-4 Properties Obtained from the Tensile Test 163 6-5 True Stress and True Strain 169 6-6 The Bend Test for Brittle Materials 171 6-7 Hardness of Materials 174 6-8 Strain Rate Effects and Impact Behavior 176 6-9 Properties Obtained from the Impact Test 177 SUMMARY 180 9 GLOSSARY 181 9 PROBLEMS 183 Chapter 7 Fracture Mechanics, Fatigue, and Creep Behavior 187 Introduction 187 7-1 Fracture Mechanics 188 7-2 The Importance of Fracture Mechanics 191 7-3 Microstructural Features of Fracture in Metallic Materials 194 7-4 Microstructural Features of Fracture in Ceramics, Glasses, and Composites 198 7-5 Weibull Statistics for Failure Strength Analysis 200 7-6 Fatigue 206 7-7 Results of the Fatigue Test 209 7-8 Application of Fatigue Testing 212 7-9 Creep, Stress Rupture, and Stress Corrosion 215 7-10 Evaluation of Creep Behavior 217 SUMMARY 220 9 GLOSSARY 220 9 PROBLEMS 222 Chapter 8 Strain Hardening and Annealing 225 Introduction 225 8-1 Relationship of Cold Working to the Stress-Strain Curve 226 8-2 Strain-Hardening Mechanisms 231 8-3 Properties versus Percent Cold Work 232 8-4 Microstructure, Texture Strengthening, and Residual Stresses 235 8-5 Characteristics of Cold Working 239 8-6 The Three Stages of Annealing 241 8-7 Control of Annealing 244 8-8 Annealing and Materials Processing 246 8-9 Hot Working 248 SUMMARY 250 9 GLOSSARY 250 9 PROBLEMS 252 CONTENTS ix Chapter 9 Principles and Applications of Solidification 257 Introduction 257 9-1 Technological Significance 258 9-2 Nucleation 259 9-3 Growth Mechanisms 264 9-4 Cooling Curves 269 9-5 Cast Structure 271 9-6 Solidification Defects 272 9-7 Casting Processes for Manufacturing Components 274 9-8 Continuous Casting, Ingot Casting, and Single Crystal Growth 276 9-9 Solidification of Polymers and Inorganic Glasses 278 9-10 Joining of Metallic Materials 279 9-11 Bulk Metallic Glasses (BMG) 280 SUMMARY 282 9 GLOSSARY 283 9 PROBLEMS 286 Chapter 10 Solid Solutions and Phase Equilibrium 291 Introduction 291 10-1 Phases and the Phase Diagram 292 10-2 Solubility and Solid Solutions 296 10-3 Conditions for Unlimited Solid Solubility 299 10-4 Solid-Solution Strengthening 301 10-5 Isomorphous Phase Diagrams 303 10-6 Relationship Between Properties and the Phase Diagram 312 10-7 Solidification of a Solid-Solution Alloy 314 SUMMARY 317 9 GLOSSARY 318 9 PROBLEMS 319 Chapter 11 Dispersion Strengthening and Eutectic Phase Diagrams 324 Introduction 324 11-1 Principles and Examples of Dispersion Strengthening 325 11-2 Intermetallic Compounds 326 11-3 Phase Diagrams Containing Three-Phase Reactions 328 11-4 The Eutectic Phase Diagram 331 11-5 Strength of Eutectic Alloys 341 11-6 Eutectics and Materials Processing 347 11-7 Nonequilibrium Freezing in the Eutectic System 349 SUMMARY 350 9 GLOSSARY 350 9 PROBLEMS 352 x CONTENTS Chapter 12 Dispersion Strengthening by Phase Transformations and Heat Treatment 357 Introduction 357 12-1 Nucleation and Growth in Solid-State Reactions 358 12-2 Alloys Strengthened by Exceeding the Solubility Limit 362 12-3 Age or Precipitation Hardening 364 12-4 Applications of Age-Hardened Alloys 364 12-5 Microstructural Evolution in Age or Precipitation Hardening 365 12-6 Effects of Aging Temperature and Time 367 12-7 Requirements for Age Hardening 369 12-8 Use of Age-Hardenable Alloys at High Temperatures 369 12-9 The Eutectoid Reaction 370 12-10 Controlling the Eutectoid Reaction 375 12-11 The Martensitic Reaction and Tempering 380 SUMMARY 384 9 GLOSSARY 385 9 PROBLEMS 387 Chapter 13 Heat Treatment of Steels and Cast Irons 391 Introduction 391 13-1 Designations and Classification of Steels 392 13-2 Simple Heat Treatments 396 13-3 Isothermal Heat Treatments 398 13-4 Quench and Temper Heat Treatments 401 13-5 Effect of Alloying Elements 406 13-6 Application of Hardenability 409 13-7 Specialty Steels 412 13-8 Surface Treatments 415 13-9 Weldability of Steel 417 13-10 Stainless Steels 418 13-11 Cast Irons 422 SUMMARY 428 9 GLOSSARY 428 9 PROBLEMS 431 Chapter 14 Nonferrous Alloys 436 Introduction 436 14-1 Aluminum Alloys 438 14-2 Magnesium and Beryllium Alloys 444 14-3 Copper Alloys 447 14-4 Nickel and Cobalt Alloys 451 CONTENTS xi 14-5 Titanium Alloys 454 14-6 Refractory and Precious Metals 462 SUMMARY 463 9 GLOSSARY 463 9 PROBLEMS 464 Chapter 15 Ceramic Materials 468 Introduction 468 15-1 Applications of Ceramics 469 15-2 Properties of Ceramics 471 15-3 Synthesis and Processing of Ceramic Powders 472 15-4 Characteristics of Sintered Ceramics 477 15-5 Inorganic Glasses 479 15-6 Glass-Ceramics 485 15-7 Processing and Applications of Clay Products 487 15-8 Refractories 488 15-9 Other Ceramic Materials 490 SUMMARY 492 9 GLOSSARY 493 9 PROBLEMS 495 Chapter 16 Polymers 496 Introduction 496 16-1 Classification of Polymers 497 16-2 Addition and Condensation Polymerization 501 16-3 Degree of Polymerization 504 16-4 Typical Thermoplastics 506 16-5 Structure–Property Relationships in Thermoplastics 509 16-6 Effect of Temperature on Thermoplastics 512 16-7 Mechanical Properties of Thermoplastics 518 16-8 Elastomers (Rubbers) 523 16-9 Thermosetting Polymers 528 16-10 Adhesives 530 16-11 Polymer Processing and Recycling 531 SUMMARY 537 9 GLOSSARY 538 9 PROBLEMS 540 Chapter 17 Composites: Teamwork and Synergy in Materials 543 Introduction 543 17-1 Dispersion-Strengthened Composites 545 17-2 Particulate Composites 547 17-3 Fiber-Reinforced Composites 553 xii CONTENTS 17-4 Characteristics of Fiber-Reinforced Composites 557 17-5 Manufacturing Fibers and Composites 564 17-6 Fiber-Reinforced Systems and Applications 568 17-7 Laminar Composite Materials 575 17-8 Examples and Applications of Laminar Composites 577 17-9 Sandwich Structures 578 SUMMARY 579 9 GLOSSARY 580 9 PROBLEMS 582 Appendix A: Selected Physical Properties of Some Elements 585 Appendix B: The Atomic and Ionic Radii of Selected Elements 587 Answers to Selected Problems 589 Index 592 CONTENTS xiii
| موضوع: رد: كتاب Essentials of Materials Science and Engineering الأحد 02 سبتمبر 2012, 8:41 pm | |
rambomenaa كبير مهندسين
عدد المساهمات : 2041 التقييم : 3379 تاريخ التسجيل : 21/01/2012 العمر : 47 الدولة : مصر العمل : مدير الصيانة بشركة تصنيع ورق الجامعة : حلوان
| موضوع: رد: كتاب Essentials of Materials Science and Engineering الإثنين 03 سبتمبر 2012, 3:02 pm | |
جزاك الله عنا خيرا . وجعلة فى ميزان حسناتك . |
| موضوع: رد: كتاب Essentials of Materials Science and Engineering الإثنين 03 سبتمبر 2012, 3:15 pm | |
- rambomenaa كتب:
- جزاك الله عنا خيرا . وجعلة فى ميزان حسناتك .
جزانا الله وإياك خيراً ونتمنى لك الإستفادة |
محمد محمد أحمد مهندس فعال جدا جدا
عدد المساهمات : 654 التقييم : 694 تاريخ التسجيل : 14/11/2012 العمر : 32 الدولة : EGYPT العمل : Student الجامعة : Menoufia
| موضوع: رد: كتاب Essentials of Materials Science and Engineering الجمعة 08 أغسطس 2014, 6:11 pm | |
